소개
This guide requires that you know how to solder components and identify which component needs to be replaced.
필요한 것
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Using a #1 phillips head screwdriver, remove the four 1cm philips head screws holding the circuit board to the inside of the toaster shell.
Inspect the circuit board for any burnt or otherwise damaged components. Be sure to carefully identify the damaged components that need replacement. For help identifying resistor values look at wikipedia's electronic color code article.
Use the soldering kit to unsolder the damaged component. For soldering Instructions look at the iFixit Soldering Guide.
다른 한 분이 해당 안내서를 완성하였습니다.
