주요 콘텐츠로 건너뛰기
PDP Afterglow Fener Battery Replacement
필요한 것
  1. PDP Afterglow Fener Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 PDP Afterglow Fener Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
  2. PDP Afterglow Fener Battery Replacement: 2 단계, 이미지 2개 중 1개 PDP Afterglow Fener Battery Replacement: 2 단계, 이미지 2개 중 2개
    • This shows what your device looks like on the inside behind the part that you just removed from the headset.
    • In the red square is the connection between the battery and the headset.
    • Gently pull the wires that are connected to the white part in the red square.
    • Now that your battery is not connected to anything you can take it out of the headset.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Murat Terzi
회원 가입일: 10/26/15
215 평판
안내서 1개를 작성함
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G3
3 회원들
안내서 10개를 작성함
댓글 한 개
Broke the headset while doing this “easy process” don’t listen to this method.
Daniel Sumida - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 7,544
