주요 콘텐츠로 건너뛰기
PDP Afterglow Fener Speaker Replacement
필요한 것
  1. PDP Afterglow Fener Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 1개 PDP Afterglow Fener Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 2개 PDP Afterglow Fener Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 3개
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    • This is a picture of what your headset looks like now that you have done the first two steps.
    • Remove the wire connected in the red box by gently pulling it off.
  2. PDP Afterglow Fener Speaker Replacement: 2 단계, 이미지 3개 중 1개 PDP Afterglow Fener Speaker Replacement: 2 단계, 이미지 3개 중 2개 PDP Afterglow Fener Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Take your soldering iron and unsolder the wire from the speaker.
    • The red square is the left tip and the orange square is the right tip.
    • Before wiring your new speaker in, clean the left and right tips with your soldering iron.
결론
작성자
2다른 기여자 명과 함께
Thomas Williams
회원 가입일: 10/22/15
512 평판
안내서 4개를 작성함
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G3
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 1,589
