주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PSP Go Trigger buttons Replacement
필요한 것
  1. PSP Go Trigger buttons Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 PSP Go Trigger buttons Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Trigger buttons Replacement: 2 단계, 이미지 2개 중 1개 PSP Go Trigger buttons Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. PSP Go Trigger buttons Replacement, Top Cover: 3 단계, 이미지 1개 중 1개
    • Pull the top cover upwards gently from its housing.
  4. PSP Go Trigger buttons Replacement, Trigger buttons: 4 단계, 이미지 1개 중 1개
    • The top cover will most likely come off during the repair, so might as well take it off now. Pull it upwards gently from its housing.
  5. PSP Go Trigger buttons Replacement: 5 단계, 이미지 1개 중 1개
    • The procedure is exactly the same for the left trigger button.
    • Use a plastic opening tool to gently flip up the left trigger connector.
  6. PSP Go Trigger buttons Replacement: 6 단계, 이미지 2개 중 1개 PSP Go Trigger buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
    • If necessary, repeat steps 2 and 3 to remove the right trigger button.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Walter Galan
709,575 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 44
지난 30일: 127
전체 시간: 12,836
