주요 콘텐츠로 건너뛰기
Palm TX Battery Pack Replacement
필요한 것
  1. Palm TX Battery Pack Replacement, Back Panel: 1 단계, 이미지 1/2 Palm TX Battery Pack Replacement, Back Panel: 1 단계, 이미지 2/2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Battery Pack Replacement: 2 단계, 이미지 1/1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Battery Pack Replacement: 3 단계, 이미지 1/2 Palm TX Battery Pack Replacement: 3 단계, 이미지 2/2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Battery Pack Replacement: 4 단계, 이미지 1/2 Palm TX Battery Pack Replacement: 4 단계, 이미지 2/2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Battery Pack Replacement: 5 단계, 이미지 1/2 Palm TX Battery Pack Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Battery Pack Replacement, Battery Pack: 6 단계, 이미지 1/2 Palm TX Battery Pack Replacement, Battery Pack: 6 단계, 이미지 2/2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Spencer Lewson
회원 가입일: 01/19/11
793 평판
안내서 6개 작성하였습니다
Cal Poly, Team 1-15, Amido Winter 2011 Cal Poly, Team 1-15, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G15
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
In step 1 - Also remove the cover hinge by sliding downwards
In step 3 - there are actually 2 crevices on the left side of the device. Use the larger, which originally held the cover hinge (the smaller crevice seems to remove the facia)
Jack - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 29
전체 시간: 7,058
