주요 콘텐츠로 건너뛰기
Panasonic ER-GN30-K Blade Replacement
  1. Panasonic ER-GN30-K Blade Replacement, Blade: 1 단계, 이미지 1개 중 1개
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Blade Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  3. Panasonic ER-GN30-K Blade Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the blade from the cap by gently pulling it from the cap.
    • Even if the blade is dull or broken, it will still be sharp enough to cut skin, so be careful while you remove it.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jacob Hoofman
회원 가입일: 09/03/15
413 평판
안내서 1개를 작성함
USF Tampa, Team 15-3, Blackwell Fall 2015 USF Tampa, Team 15-3, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S15G3
4 회원들
안내서 10개를 작성함
댓글 6개
Looked everywhere...anybody know where to get replacement blades for the Panasonic ER-GN30 nose & ear trimmer?
R Holmes - 답글
Did you ever find a replacement blade?
PCARRINGTON - 답글
I called Panasonic's support number, and supposedly the inner blade at least, is priced from around $14 to $20, from various places. Considering major resellers have the whole trimmer for around $12, it would not make sense to get just a blade. Amazon has open-box wearhouse deals now, where the trimmers can be had for under $5.00. I may get one of these myself :)
Jim Locke - 답글
Hola yo acabo de comprar las cuchillas a 7€ , les dejo el enlace https://juanluismartel.com ademas me repararon una camara Panasonic Lumix, Gracias.
usblsb - 답글
Why would a nose hair trimmer need a replacement blade? And this particularly blade is more expensive then the trimmer itself.
Caba Alex - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 27
지난 30일: 64
전체 시간: 13,551
