주요 콘텐츠로 건너뛰기
Panasonic KX-TG6641 Earpiece Replacement
필요한 것
  1. Panasonic KX-TG6641 Earpiece Replacement, Battery: 1 단계, 이미지 1/2 Panasonic KX-TG6641 Earpiece Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the battery cover by sliding the cover piece down
  2. Panasonic KX-TG6641 Earpiece Replacement: 2 단계, 이미지 1/2 Panasonic KX-TG6641 Earpiece Replacement: 2 단계, 이미지 2/2
    • Remove the two AAA batteries.
  3. Panasonic KX-TG6641 Earpiece Replacement, Earpiece: 3 단계, 이미지 1/1
    • In order to remove the back of the phone, unscrew the two screws at the bottom corners on the back of the phone.
  4. Panasonic KX-TG6641 Earpiece Replacement: 4 단계, 이미지 1/2 Panasonic KX-TG6641 Earpiece Replacement: 4 단계, 이미지 2/2
    • In order to remove the back of the phone, pry the back open by inserting the iFixit Opening tool in the space between the front and back of the phone.
  5. Panasonic KX-TG6641 Earpiece Replacement: 5 단계, 이미지 1/2 Panasonic KX-TG6641 Earpiece Replacement: 5 단계, 이미지 2/2
    • Remove the earpiece cover by twisting the plastic earpiece clockwise to unlock.
  6. Panasonic KX-TG6641 Earpiece Replacement: 6 단계, 이미지 1/1
    • Replace earpiece by heating wires with soldering iron.
    • Solder wires back to earpiece after installing the replacement earpiece.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph Byrne
회원 가입일: 04/08/19
472 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 273
