주요 콘텐츠로 건너뛰기
Panasonic KX-TGA600M Speaker Replacement
필요한 것
  1. Panasonic KX-TGA600M Speaker Replacement, Battery: 1 단계, 이미지 1/2 Panasonic KX-TGA600M Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • On the back of the phone, remove battery cover.
    • Push down on the marked indentation and pull downwards.
  2. Panasonic KX-TGA600M Speaker Replacement: 2 단계, 이미지 1/1
    • Pull out to remove the battery.
  3. Panasonic KX-TGA600M Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Unscrew the two screws on the bottom left and right.
  4. Panasonic KX-TGA600M Speaker Replacement: 4 단계, 이미지 1/2 Panasonic KX-TGA600M Speaker Replacement: 4 단계, 이미지 2/2
    • Separate the front and back of the phone.
    • Store loose pieces for later replacement.
  5. Panasonic KX-TGA600M Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the speaker housing.
    • During reassembly, solder the wires onto the speaker housing. For information on soldering, please refer to iFixit's soldering technique guide.
결론
Kaleb Barquera
회원 가입일: 01/31/17
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 17
전체 시간: 660
