주요 콘텐츠로 건너뛰기
소개
Step by step guide to replacing your digital camera door.
부품
  1. Panasonic Lumix DMC-ZS1 Door Replacement, Exterior Screw removal: step 1, image 1 of 3 Panasonic Lumix DMC-ZS1 Door Replacement, Exterior Screw removal: step 1, image 2 of 3 Panasonic Lumix DMC-ZS1 Door Replacement, Exterior Screw removal: step 1, image 3 of 3
    • Remove the battery and memory card from the unit
    • Remove 6 (0.3mm) screws from the sides of the unit
    • Remove 5 (0.3mm) screws from the bottom of the unit
  2. Panasonic Lumix DMC-ZS1 Door Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-ZS1 Door Replacement: step 2, image 2 of 2
    • Lift up slightly the rear cover.
    • Do not remove rear cover yet. It is still attached to the Main PCB.
    • Flip up the cable clamps using a spudger or other device. Careful not to break the clamps. Release flex cables and remove back cover.
  3. Panasonic Lumix DMC-ZS1 Door Replacement: step 3, image 1 of 3 Panasonic Lumix DMC-ZS1 Door Replacement: step 3, image 2 of 3 Panasonic Lumix DMC-ZS1 Door Replacement: step 3, image 3 of 3
    • Release the 3 metal clips from the rear cover and remove the LCD
  4. Panasonic Lumix DMC-ZS1 Door Replacement, Door: step 4, image 1 of 3 Panasonic Lumix DMC-ZS1 Door Replacement, Door: step 4, image 2 of 3 Panasonic Lumix DMC-ZS1 Door Replacement, Door: step 4, image 3 of 3
    • Complete the following review guide: LCD removal
    • Remove the front cover
    • Use tweezers or a thin object to push door pin thru enough to grab from the other side.
    • Keep door closed during this procedure so you will not loose the spring.
  5. Panasonic Lumix DMC-ZS1 Door Replacement: step 5, image 1 of 3 Panasonic Lumix DMC-ZS1 Door Replacement: step 5, image 2 of 3 Panasonic Lumix DMC-ZS1 Door Replacement: step 5, image 3 of 3
    • Try to keep the door closed during this procedure.
    • Pull out door pin using needle nose pliers or other tool.
    • Notice spring positioning. This will help you re-install your replacement door
    • If you are having trouble installing, try to keep the spring in place by using a small piece of tape.
    • Replacement Door
결론
Sales Cameraparts4you
회원 가입일: 2016년 07월 01일
2,934 평판
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 94
