주요 콘텐츠로 건너뛰기
Panasonic RQ-2102 Holding Handle Replacement
필요한 것
  1. Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: 1 단계, 이미지 1/3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: 1 단계, 이미지 2/3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: 1 단계, 이미지 3/3
    • Remove the three M5-0.8 x 12 mm Phillips #0 screws from the back of the device body.
    • There are two more screws inside the battery compartment. Remove those as well.
    • Cautiously remove the back of the device body. Be sure not to damage the cord that connects the two sides.
    • All of the screws are the same size.
  2. Panasonic RQ-2102 Holding Handle Replacement: 2 단계, 이미지 1/2 Panasonic RQ-2102 Holding Handle Replacement: 2 단계, 이미지 2/2
    • Carefully remove the handle. Make sure the handle catches on each side are intact.
    • Replace the old handle with the new handle.
    • Remember, if the handle catches are broken, the device must be replaced.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew Campbell
회원 가입일: 04/07/15
276 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 9
전체 시간: 562
