주요 콘텐츠로 건너뛰기
Panasonic Toughbook CF-29 Motherboard Replacement
필요한 것
  1. Panasonic Toughbook CF-29 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Motherboard Replacement: 2 단계, 이미지 1/2 Panasonic Toughbook CF-29 Motherboard Replacement: 2 단계, 이미지 2/2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Motherboard Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Locate the door for the hard drive on the right side of the laptop
  4. Panasonic Toughbook CF-29 Motherboard Replacement: 4 단계, 이미지 1/2 Panasonic Toughbook CF-29 Motherboard Replacement: 4 단계, 이미지 2/2
    • Push and slide the latch up to open the hard drive door.
    • Pull out the hard drive.
  5. Panasonic Toughbook CF-29 Motherboard Replacement, Optical Drive: 5 단계, 이미지 1/1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  6. Panasonic Toughbook CF-29 Motherboard Replacement: 6 단계, 이미지 1/1
    • Slide the latch cover to the right.
  7. Panasonic Toughbook CF-29 Motherboard Replacement: 7 단계, 이미지 1/2 Panasonic Toughbook CF-29 Motherboard Replacement: 7 단계, 이미지 2/2
    • Push the exposed switch to the left to eject the optical drive.
  8. Panasonic Toughbook CF-29 Motherboard Replacement, Back Cover: 8 단계, 이미지 1/1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  9. Panasonic Toughbook CF-29 Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  10. Panasonic Toughbook CF-29 Motherboard Replacement: 10 단계, 이미지 1/1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  11. Panasonic Toughbook CF-29 Motherboard Replacement: 11 단계, 이미지 1/2 Panasonic Toughbook CF-29 Motherboard Replacement: 11 단계, 이미지 2/2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  12. Panasonic Toughbook CF-29 Motherboard Replacement: 12 단계, 이미지 1/1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  13. Panasonic Toughbook CF-29 Motherboard Replacement: 13 단계, 이미지 1/1
    • Now the back cover should be off and you can access the inside of the casing.
  14. Panasonic Toughbook CF-29 Motherboard Replacement, Wireless Card: 14 단계, 이미지 1/1
    • Remove the black and white wires attached to the wireless card by simply pulling up.
  15. Panasonic Toughbook CF-29 Motherboard Replacement: 15 단계, 이미지 1/1
    • Peel back the black cover to expose the clips holding in the wireless card.
  16. Panasonic Toughbook CF-29 Motherboard Replacement: 16 단계, 이미지 1/1
    • Using a pair of plastic opening tools, push the two metal tabs away from the card.
  17. Panasonic Toughbook CF-29 Motherboard Replacement: 17 단계, 이미지 1/2 Panasonic Toughbook CF-29 Motherboard Replacement: 17 단계, 이미지 2/2
    • The wireless card should now easily disengage from the motherboard.
    • Pull the card horizontally away from you to remove it from its housing.
  18. Panasonic Toughbook CF-29 Motherboard Replacement, Motherboard: 18 단계, 이미지 1/2 Panasonic Toughbook CF-29 Motherboard Replacement, Motherboard: 18 단계, 이미지 2/2
    • Unplug 3 cables
    • Lift up on brown tab to release cable
    • Pull cable up and out
  19. Panasonic Toughbook CF-29 Motherboard Replacement: 19 단계, 이미지 1/2 Panasonic Toughbook CF-29 Motherboard Replacement: 19 단계, 이미지 2/2
    • Remove 2 long screws indicated with red circles
    • Remove the remaining screws indicated in blue
  20. Panasonic Toughbook CF-29 Motherboard Replacement: 20 단계, 이미지 1/1
    • On the back of the unit, unscrew the three screws surrounding the serial port.
  21. Panasonic Toughbook CF-29 Motherboard Replacement: 21 단계, 이미지 1/1
    • Lift the motherboard as shown, pull towards you and then up.
    • Do not yet try to fully remove the motherboard or you may destroy the connections
  22. Panasonic Toughbook CF-29 Motherboard Replacement: 22 단계, 이미지 1/1
    • Detach the white ribbon cable, the white cluster connector, and the ribbon cable right next to the cluster
  23. Panasonic Toughbook CF-29 Motherboard Replacement: 23 단계, 이미지 1/2 Panasonic Toughbook CF-29 Motherboard Replacement: 23 단계, 이미지 2/2
    • Remove the board.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Dylan Bloom
회원 가입일: 04/12/10
373 평판
안내서 4개 작성하였습니다
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G93
4 회원들
안내서 26개 작성하였습니다
댓글 4개
what about spare parts? is it possible cange MOBO and CPU?  in order to upgrade the thoughbook?
Concetto Salierno - 답글
I think y'all missed a step.
Gemini - 답글
Où acheter la carte mère?
MERCI
Pascal Cohu - 답글
Sur Google, recherchez "DL3UP1396AAA Panasonic CF-29 System Board" (à rechercher sans les guillemets), vous aurez quelques résultats (j'ai vu au moins 2 sites qui la propose à la vente), par contre, elle est cher.
Autre recherche possible : "DL3UP1396BAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Autre recherche possible : "DL3U11213FAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Brendan -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 32
전체 시간: 25,884
