주요 콘텐츠로 건너뛰기
Parrot Skycontroller 2 Power Port Replacement
필요한 것
  1. Parrot Skycontroller 2 Power Port  Replacement, Power Port: 1 단계, 이미지 1/3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: 1 단계, 이미지 2/3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: 1 단계, 이미지 3/3
    • Flip the controller upside down.
  2. Parrot Skycontroller 2 Power Port  Replacement: 2 단계, 이미지 1/1
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Power Port  Replacement: 3 단계, 이미지 1/3 Parrot Skycontroller 2 Power Port  Replacement: 3 단계, 이미지 2/3 Parrot Skycontroller 2 Power Port  Replacement: 3 단계, 이미지 3/3
    • Insert the plastic opening tool into the top of the battery cover and pry upwards to lift the cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Power Port  Replacement: 4 단계, 이미지 1/3 Parrot Skycontroller 2 Power Port  Replacement: 4 단계, 이미지 2/3 Parrot Skycontroller 2 Power Port  Replacement: 4 단계, 이미지 3/3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling apart.
  5. Parrot Skycontroller 2 Power Port  Replacement: 5 단계, 이미지 1/2 Parrot Skycontroller 2 Power Port  Replacement: 5 단계, 이미지 2/2
    • Remove the battery from it's brackets by pulling up gently on the ends of the battery.
    • Some force may be required to separate the battery from it's brackets.
  6. Parrot Skycontroller 2 Power Port  Replacement: 6 단계, 이미지 1/1
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
  7. Parrot Skycontroller 2 Power Port  Replacement: 7 단계, 이미지 1/3 Parrot Skycontroller 2 Power Port  Replacement: 7 단계, 이미지 2/3 Parrot Skycontroller 2 Power Port  Replacement: 7 단계, 이미지 3/3
    • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
  8. Parrot Skycontroller 2 Power Port  Replacement: 8 단계, 이미지 1/1
    • Remove the battery compartment plate by pulling up and out.
  9. Parrot Skycontroller 2 Power Port  Replacement: 9 단계, 이미지 1/1
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
  10. Parrot Skycontroller 2 Power Port  Replacement: 10 단계, 이미지 1/3 Parrot Skycontroller 2 Power Port  Replacement: 10 단계, 이미지 2/3 Parrot Skycontroller 2 Power Port  Replacement: 10 단계, 이미지 3/3
    • Remove the face plate by pulling up and out.
  11. Parrot Skycontroller 2 Power Port  Replacement: 11 단계, 이미지 1/3 Parrot Skycontroller 2 Power Port  Replacement: 11 단계, 이미지 2/3 Parrot Skycontroller 2 Power Port  Replacement: 11 단계, 이미지 3/3
    • Make sure the controller is flat, then proceed to desolder the power port.
    • Desolder the four connection points surrounding the charging port.
    • Remove the power port from the controller.
    • For help with soldering best practices, check out our How to Solder and Desolder Connections guide.
    • Excessive heat can damage the power port, so do not apply the soldering iron to the component for too long.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 12
전체 시간: 428
