주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Patching a Bicycle Tire Inner Tube
필요한 것
  1. Patching a Bicycle Tire Inner Tube, Inner Tube: 1 단계, 이미지 1개 중 1개
    • Press the valve core while applying pressure to the tire to deflate the tire.
  2. Patching a Bicycle Tire Inner Tube: 2 단계, 이미지 2개 중 1개 Patching a Bicycle Tire Inner Tube: 2 단계, 이미지 2개 중 2개
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  3. Patching a Bicycle Tire Inner Tube: 3 단계, 이미지 1개 중 1개
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  4. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: 4 단계, 이미지 2개 중 1개 Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: 4 단계, 이미지 2개 중 2개
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  5. Patching a Bicycle Tire Inner Tube: 5 단계, 이미지 1개 중 1개
    • Mark the hole with a marker, and completely deflate the tire.
  6. Patching a Bicycle Tire Inner Tube: 6 단계, 이미지 1개 중 1개
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  7. Patching a Bicycle Tire Inner Tube: 7 단계, 이미지 1개 중 1개
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  8. Patching a Bicycle Tire Inner Tube: 8 단계, 이미지 1개 중 1개
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  9. Patching a Bicycle Tire Inner Tube: 9 단계, 이미지 1개 중 1개
    • Apply the patch to the area.
  10. Patching a Bicycle Tire Inner Tube: 10 단계, 이미지 1개 중 1개
    • Apply pressure to the patch until the rubber cement is dry.
결론
To reassemble your bike, follow these directions from step 6
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
131,426 평판
안내서 144개를 작성함
iFixit iFixit 회원
Staff
125 회원들
안내서 24,044개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 26
전체 시간: 2,106
