주요 콘텐츠로 건너뛰기
Pentax Optio WG-2 Menu Buttons Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. 주의: 1-6 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Pentax Optio WG-2 Menu Buttons Replacement, Back Case: 1 단계, 이미지 1/2 Pentax Optio WG-2 Menu Buttons Replacement, Back Case: 1 단계, 이미지 2/2
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 Menu Buttons Replacement: 2 단계, 이미지 1/1
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 Menu Buttons Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 Menu Buttons Replacement: 4 단계, 이미지 1/3 Pentax Optio WG-2 Menu Buttons Replacement: 4 단계, 이미지 2/3 Pentax Optio WG-2 Menu Buttons Replacement: 4 단계, 이미지 3/3
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 Menu Buttons Replacement: 5 단계, 이미지 1/1
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 Menu Buttons Replacement: 6 단계, 이미지 1/1
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 Menu Buttons Replacement, Menu Buttons: 7 단계, 이미지 1/2 Pentax Optio WG-2 Menu Buttons Replacement, Menu Buttons: 7 단계, 이미지 2/2
    • Remove the eight JS#000 screws using a screwdriver and lift panel up.
    • This screw does not need to be removed.
  8. Pentax Optio WG-2 Menu Buttons Replacement: 8 단계, 이미지 1/1
    • Once panel is removed the button 'sheet' can be removed.
결론
Matthew Bessette
회원 가입일: 03/04/16
658 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 UMass Dartmouth, Team 6-7, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G7
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 198
