소개
This is a guide on how to replace the speakers on a Philips DS3000/37 Audio Dock. Because this repair requires soldering, the soldering technique page linked here might be helpful. How To Solder and Desolder Connections
필요한 것
Pry off the front fascia by inserting a plastic opening tool between the fascia and white casing.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
i hardly difficult to treat 2 defective speakers. i find the flat cable a little loose on the main plate. thank you!!!
araujojraa - 답글
