주요 콘텐츠로 건너뛰기
Philips Norelco 5801XL Battery Replacement
필요한 것
  1. Philips Norelco 5801XL Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Philips Norelco 5801XL Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using a T8 torx screwdriver, remove both 2mm T8 screws.
  2. Philips Norelco 5801XL Battery Replacement: 2 단계, 이미지 2개 중 1개 Philips Norelco 5801XL Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, separate the front housing from the back housing.
    • Carefully pull the housing apart.
  3. Philips Norelco 5801XL Battery Replacement: 3 단계, 이미지 3개 중 1개 Philips Norelco 5801XL Battery Replacement: 3 단계, 이미지 3개 중 2개 Philips Norelco 5801XL Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the plastic bracket using a plastic opening tool.
    • Pry from the inside of the bracket towards the outside of the housing to remove it.
  4. Philips Norelco 5801XL Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
    • Remove the bracket. It will pull straight out.
  5. Philips Norelco 5801XL Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Push in the charge port using the plastic opening tool.
  6. Philips Norelco 5801XL Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the circuit board upwards and fold it towards the head of the razor.
    • Do not break the contacts connecting the board to the motor.
  7. Philips Norelco 5801XL Battery Replacement: 7 단계, 이미지 3개 중 1개 Philips Norelco 5801XL Battery Replacement: 7 단계, 이미지 3개 중 2개 Philips Norelco 5801XL Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Desolder the contacts where the battery connects to the circuit board.
    • Straighten the battery contacts and pull them through the opposite side of the circuit board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ben Gibbs
회원 가입일: 02/16/16
361 평판
안내서 3개를 작성함
IUPUI, Team 3-2, Harley Spring 2016 IUPUI, Team 3-2, Harley Spring 2016 회원
IUPUI-HARLEY-S16S3G2
4 회원들
안내서 6개를 작성함
댓글 3개
The replacement battery I bought had contact strips that were too long and too wide for the slots on the circuit board, so I had to trim off about half the length and 1.5 mm of the width on each strip, but after that alteration, it worked fine.
Tom Hess - 답글
What size is the Rechargeable Battery in the Norelco 5801XL .
Dave - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 22
전체 시간: 4,375
