주요 콘텐츠로 건너뛰기
Philips Norelco MultiGroom 3100 Motor Replacement
필요한 것
  1. Philips Norelco MultiGroom 3100 Motor Replacement, Power Button: 1 단계, 이미지 1개 중 1개
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Motor Replacement: 2 단계, 이미지 2개 중 1개 Philips Norelco MultiGroom 3100 Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Motor Replacement: 3 단계, 이미지 2개 중 1개 Philips Norelco MultiGroom 3100 Motor Replacement: 3 단계, 이미지 2개 중 2개
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Motor Replacement, Casing: 5 단계, 이미지 2개 중 1개 Philips Norelco MultiGroom 3100 Motor Replacement, Casing: 5 단계, 이미지 2개 중 2개
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Motor Replacement: 6 단계, 이미지 2개 중 1개 Philips Norelco MultiGroom 3100 Motor Replacement: 6 단계, 이미지 2개 중 2개
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
  7. Philips Norelco MultiGroom 3100 Motor Replacement, Motor: 7 단계, 이미지 2개 중 1개 Philips Norelco MultiGroom 3100 Motor Replacement, Motor: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tweezers to pull out the inner power button.
  8. Philips Norelco MultiGroom 3100 Motor Replacement: 8 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to separate the clip on the right side of the inner housing.
  9. Philips Norelco MultiGroom 3100 Motor Replacement: 9 단계, 이미지 2개 중 1개 Philips Norelco MultiGroom 3100 Motor Replacement: 9 단계, 이미지 2개 중 2개
    • Push the inner housing up and to the right to separate the left clip from the battery casing.
    • Push the inner housing upwards to separate it from the battery casing.
  10. Philips Norelco MultiGroom 3100 Motor Replacement: 10 단계, 이미지 2개 중 1개 Philips Norelco MultiGroom 3100 Motor Replacement: 10 단계, 이미지 2개 중 2개
    • Use the tweezers to hold the wire steady as you unsolder the blue wire from the power switch.
    • Use the tweezers to remove the power switch.
    • For help with soldering check out the iFixit Soldering Technique Guide.
  11. Philips Norelco MultiGroom 3100 Motor Replacement: 11 단계, 이미지 3개 중 1개 Philips Norelco MultiGroom 3100 Motor Replacement: 11 단계, 이미지 3개 중 2개 Philips Norelco MultiGroom 3100 Motor Replacement: 11 단계, 이미지 3개 중 3개
    • Pull up on the motor to remove it from the battery casing.
    • Use the tweezers to hold the black wire steady while unsoldering it from the base of the battery.
    • Using the tweezers, pull on the black wire to remove it from the base of the battery.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
ahaharevolution
회원 가입일: 10/04/15
819 평판
안내서 3개를 작성함
USF Tampa, Team 1-1, Leahy Fall 2015 USF Tampa, Team 1-1, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G1
2 회원들
안내서 6개를 작성함
4가이드 댓글
¿Me puedes ayudar con algo?
Johan Avendaño - 답글
Can you help me with something?
Johan Avendaño - 답글
this guide was created also by nina lovekrist in 2015
Nina Lovekrist - 답글
Where can I get the motor with copper shaft?
amal.hardik - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 46
전체 시간: 5,240
