소개
The suppression capacitor in the Senseo Quadrante unfortunately often breaks down. The machine then no longer starts or the pump fails. The exchange is quite simple. You need a 0.47uF capacitor, class X2, at least 275 V, 22 mm pitch, which is easily available at any electronics store.
The repair goes quite similar to other devices
필요한 것
Remove all attachments such as cup rack, pod holder and water tank.
The side panel must first be detached at the bottom edge. Turn the machine so that the bottom is facing towards you.
There are two indentations on the base plate with catches inside each one. Press in the catches with a screwdriver and detach the side panel at the bottom edge.
Chances are the plate will get stuck. It is recommended that you use a plastic pry tool to avoid scratching.
Work through the steps in reverse order to reassemble your device.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
shingle님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 2개
Let op de + en - aansluiting van de condensator!
Dit type condensator heeft geen polariteit. Heb je de verkeerde condensator geïnstalleerd?
VauWeh -
