주요 콘텐츠로 건너뛰기
Philips Sonicare 2 Series Circuit Board Replacement
필요한 것
  1. Philips Sonicare 2 Series Circuit Board Replacement, Philips Sonicare 2 Series Disassembly: 1 단계, 이미지 1/1
    • Pull upwards to remove the brush head from the top of the device.
  2. Philips Sonicare 2 Series Circuit Board Replacement: 2 단계, 이미지 1/1
    • Remove the 12 mm T8 Torx screw from the bottom of the toothbrush. After removing the screw, pry off the base with a plastic opening tool.
  3. Philips Sonicare 2 Series Circuit Board Replacement: 3 단계, 이미지 1/2 Philips Sonicare 2 Series Circuit Board Replacement: 3 단계, 이미지 2/2
    • Remove the internal electronic mechanism from the housing by prying the red clips shown in the figure. This removes the charging port.
    • Be very careful not to damage the charging port during this step. Otherwise you will have to solder this part back to the device as shown in the second figure.
  4. Philips Sonicare 2 Series Circuit Board Replacement: 4 단계, 이미지 1/1
    • Next you will be able to remove the internal electronic mechanism as shown in the figure.
  5. Philips Sonicare 2 Series Circuit Board Replacement: 5 단계, 이미지 1/1
    • Remove the white battery cover as shown in the figure.
  6. Philips Sonicare 2 Series Circuit Board Replacement: 6 단계, 이미지 1/1
    • Remove the white circuit board cover as shown. This cover will require you to pry off the piece from the groves .
  7. Philips Sonicare 2 Series Circuit Board Replacement, Circuit Board: 7 단계, 이미지 1/1
    • Pry away the battery using an opening tool from the battery housing. This will break the circuit and avoid electric shock.
  8. Philips Sonicare 2 Series Circuit Board Replacement: 8 단계, 이미지 1/1
    • Desolder the circuit board from the motor as shown.
  9. Philips Sonicare 2 Series Circuit Board Replacement: 9 단계, 이미지 1/1
    • Desolder the circuit board from the housing as shown to remove the board
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jonathan Jarvis
회원 가입일: 04/01/16
491 평판
안내서 4개 작성하였습니다
IUPUI, Team S6-G2, Baechle Fall 2017 IUPUI, Team S6-G2, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S6G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 1,644
