주요 콘텐츠로 건너뛰기
Philips Sonicare 9350 Battery Replacement
필요한 것
  1. Philips Sonicare 9350 Battery Replacement, Head removal: 1 단계, 이미지 1/2 Philips Sonicare 9350 Battery Replacement, Head removal: 1 단계, 이미지 2/2
    • Remove the toothbrush head.
    • Use a screwdriver to pry gently around the bottom of the toothbrush.
  2. Philips Sonicare 9350 Battery Replacement, Remove the bottom: 2 단계, 이미지 1/3 Philips Sonicare 9350 Battery Replacement, Remove the bottom: 2 단계, 이미지 2/3 Philips Sonicare 9350 Battery Replacement, Remove the bottom: 2 단계, 이미지 3/3
    • After the bottom of the toothbrush is pried loose, remove it from the base of the brush.
  3. Philips Sonicare 9350 Battery Replacement: 3 단계, 이미지 1/3 Philips Sonicare 9350 Battery Replacement: 3 단계, 이미지 2/3 Philips Sonicare 9350 Battery Replacement: 3 단계, 이미지 3/3
    • Use a spudger to open the two clasps inside the toothbrush handle in a downward motion.
    • Turn the toothbrush upside down and push down on a hard surface—this will slide the toothbrush's internal body out.
  4. Philips Sonicare 9350 Battery Replacement, Extract the internals: 4 단계, 이미지 1/2 Philips Sonicare 9350 Battery Replacement, Extract the internals: 4 단계, 이미지 2/2
    • Pull out the internals of the toothbrush.
  5. Philips Sonicare 9350 Battery Replacement, Access the battery: 5 단계, 이미지 1/2 Philips Sonicare 9350 Battery Replacement, Access the battery: 5 단계, 이미지 2/2
    • Open the protective cover of the battery.
    • Check the battery model.
    • In this case, the model is a Sony 680mhA lithium battery.
  6. Philips Sonicare 9350 Battery Replacement, Desolder both terminals: 6 단계, 이미지 1/3 Philips Sonicare 9350 Battery Replacement, Desolder both terminals: 6 단계, 이미지 2/3 Philips Sonicare 9350 Battery Replacement, Desolder both terminals: 6 단계, 이미지 3/3
    • Open the protection cover of the circuit board.
    • Find the welding points of the positive and negative electrodes of the battery and use the soldering iron to desolder.
    • The battery will fall off after desoldering as shown in the figure.
    • Be careful not to touch other parts of the circuit board when desoldering.
  7. Philips Sonicare 9350 Battery Replacement, Install a new battery: 7 단계, 이미지 1/3 Philips Sonicare 9350 Battery Replacement, Install a new battery: 7 단계, 이미지 2/3 Philips Sonicare 9350 Battery Replacement, Install a new battery: 7 단계, 이미지 3/3
    • Use a spudger to pry the battery out at a 45 degree angle.
    • After successfully removing the battery, install the new battery using the reverse procedure.
    • Always use ESD safe tools when working on a circuit board or with batteries such as a nylon spudger.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Dongyi Lin
회원 가입일: 05/10/21
252 평판
안내서 1개 작성함
York University, Team S1-G16, O'Regan Summer 2021 York University, Team S1-G16, O'Regan Summer 2021 회원
YORK-O'REGAN-SU21S1G16
1 회원
안내서 3개 작성하였습니다
댓글 한 개
All good advice and it works too. Ignore Philips advice that the battery is not replaceable. It is, with correct knowledge and understanding. Thanks for posting.
Shreds - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 60
30일 전: 271
전체 시간: 9,452
