주요 콘텐츠로 건너뛰기
Philips Sonicare DiamondClean Circuit Board Replacement
필요한 것
  1. Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1/2 Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: 1 단계, 이미지 2/2
    • Pull the brush head from the toothbrush.
  2. Philips Sonicare DiamondClean Circuit Board Replacement: 2 단계, 이미지 1/1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Circuit Board Replacement: 3 단계, 이미지 1/3 Philips Sonicare DiamondClean Circuit Board Replacement: 3 단계, 이미지 2/3 Philips Sonicare DiamondClean Circuit Board Replacement: 3 단계, 이미지 3/3
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
  4. Philips Sonicare DiamondClean Circuit Board Replacement: 4 단계, 이미지 1/1
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Circuit Board Replacement: 5 단계, 이미지 1/1
    • Carefully free the top end of the circuit board from the plastic clips holding it in place.
  6. Philips Sonicare DiamondClean Circuit Board Replacement: 6 단계, 이미지 1/1
    • Use the soldering iron to desolder the terminals marked F1, C5, R7, R6, and JP1.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
    • Remove the circuit board.
결론
Caleb Watson
회원 가입일: 09/16/20
472 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 64
전체 시간: 2,717
