주요 콘텐츠로 건너뛰기
Philips Sonicare DiamondClean Motor Replacement
필요한 것
  1. Philips Sonicare DiamondClean Motor Replacement, Motor: 1 단계, 이미지 1/2 Philips Sonicare DiamondClean Motor Replacement, Motor: 1 단계, 이미지 2/2
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Motor Replacement: 2 단계, 이미지 1/1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Motor Replacement: 3 단계, 이미지 1/2 Philips Sonicare DiamondClean Motor Replacement: 3 단계, 이미지 2/2
    • Place the toothbrush upside down on a solid object and firmly, but gently, push down on the toothbrush until the internal components and case separate.
    • Note that there are clips inside the case but they are hard to access and unneeded to separate the components.
  4. Philips Sonicare DiamondClean Motor Replacement: 4 단계, 이미지 1/2 Philips Sonicare DiamondClean Motor Replacement: 4 단계, 이미지 2/2
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Motor Replacement: 5 단계, 이미지 1/1
    • Using a soldering iron, remove the solder from the positions marked 1 and 2 on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
  6. Philips Sonicare DiamondClean Motor Replacement: 6 단계, 이미지 1/1
    • Slide and separate the two components of the internals from each other.
  7. Philips Sonicare DiamondClean Motor Replacement: 7 단계, 이미지 1/1
    • Gently remove the spring and rubber component.
  8. Philips Sonicare DiamondClean Motor Replacement: 8 단계, 이미지 1/2 Philips Sonicare DiamondClean Motor Replacement: 8 단계, 이미지 2/2
    • Remove the two 4mm Phillips #00 screws on both sides of the upper component.
  9. Philips Sonicare DiamondClean Motor Replacement: 9 단계, 이미지 1/2 Philips Sonicare DiamondClean Motor Replacement: 9 단계, 이미지 2/2
    • Gently bend and position the brackets to remove the motor.
  10. Philips Sonicare DiamondClean Motor Replacement: 10 단계, 이미지 1/1
    • Remove the motor and replace.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Caleb Watson
회원 가입일: 09/16/20
482 평판
안내서 3개 작성하였습니다
댓글 2개
Do you have a part number for the motor?
Suraj Daryapurkar - 답글
Double check if the vibrating end on step 4 is screwed tight. On my unit, I though the motor had an issue, whereas it just was that a screw on the vibrating end that had gotten loose.
Marsya Kaustentein - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 39
30일 전: 139
전체 시간: 6,193
