주요 콘텐츠로 건너뛰기
Photive Rain Motherboard Replacement
필요한 것
  1. Photive Rain Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Motherboard Replacement, Battery: 3 단계, 이미지 1/2 Photive Rain Motherboard Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the plastic cover in front of the battery slot.
    • Unscrew all the 8.5mm screws that hold the cover to the slot.
    • Separate the battery from the back panel as shown in photograph 3.
    • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
  4. Photive Rain Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the motherboard.
    • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
    • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
  5. Photive Rain Motherboard Replacement, Speaker: 5 단계, 이미지 1/1
    • Carefully remove the front panel from the device.
  6. Photive Rain Motherboard Replacement: 6 단계, 이미지 1/1
    • Detach the connector clips from the motherboard using the iFixit Opening Tool.
    • Some force may be necessary to remove the plastic clips.
  7. Photive Rain Motherboard Replacement: 7 단계, 이미지 1/2 Photive Rain Motherboard Replacement: 7 단계, 이미지 2/2
    • After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
  8. Photive Rain Motherboard Replacement, Motherboard: 8 단계, 이미지 1/1
    • From the back of the motherboard, unscrew the three phillips head screws holding the motherboard in place.
  9. Photive Rain Motherboard Replacement: 9 단계, 이미지 1/1
    • Pull the rubber away from the edge of the motherboard.
  10. Photive Rain Motherboard Replacement: 10 단계, 이미지 1/2 Photive Rain Motherboard Replacement: 10 단계, 이미지 2/2
    • Use the plastic opening tool to remove motherboard from device.
    • The second photograph displays a properly removed motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
abcdef ghijk
회원 가입일: 02/15/16
723 평판
안내서 4개 작성하였습니다
IUPUI, Team 1-4, Harley Spring 2016 IUPUI, Team 1-4, Harley Spring 2016 회원
IUPUI-HARLEY-S16S1G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 285
