주요 콘텐츠로 건너뛰기
Pine64 PinePhone Front and Rear Camera Replacement
필요한 것
  1. Pine64 PinePhone Front and Rear Camera Replacement, Place the device facing down: 1 단계, 이미지 2개 중 1개 Pine64 PinePhone Front and Rear Camera Replacement, Place the device facing down: 1 단계, 이미지 2개 중 2개
    • Place the device face down on a non-scratch surface.
    • Ensure the device is powered off before removing the case as removing the battery or making internal changes could cause physical or hardware damage to the phone
  2. Pine64 PinePhone Front and Rear Camera Replacement, Remove the back cover: 2 단계, 이미지 1개 중 1개
    • Using a fingernail pry open the back cover off with the bottom left indent.
    • A notch to easily remove the cover is located at the bottom left of the PinePhone with the back cover facing the user.
  3. Pine64 PinePhone Front and Rear Camera Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using a fingernail, press into the bottom divot and remove the battery from the phone.
  4. Pine64 PinePhone Front and Rear Camera Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Use a spudger or plastic opening tool to pry off the plastic cover.
  5. Pine64 PinePhone Front and Rear Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Use a spudger to lift the ZIF tabs and press-fit connectors free.
  6. Pine64 PinePhone Front and Rear Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Use a spudger to lift the motherboard up and remove it from the device.
  7. Pine64 PinePhone Front and Rear Camera Replacement, Front and Rear Camera: 7 단계, 이미지 1개 중 1개
    • Use a spudger to remove the rear camera.
  8. Pine64 PinePhone Front and Rear Camera Replacement: 8 단계, 이미지 1개 중 1개
    • Use a spudger to remove the front camera.
결론
다른 3명이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 654
