주요 콘텐츠로 건너뛰기
PlayStation 2 Slimline PVR-802W Laser Replacement
필요한 것
  1. PlayStation 2 Slimline PVR-802W Laser Replacement, Outer Shell: 1 단계, 이미지 1개 중 1개
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline PVR-802W Laser Replacement: 2 단계, 이미지 3개 중 1개 PlayStation 2 Slimline PVR-802W Laser Replacement: 2 단계, 이미지 3개 중 2개 PlayStation 2 Slimline PVR-802W Laser Replacement: 2 단계, 이미지 3개 중 3개
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline PVR-802W Laser Replacement: 3 단계, 이미지 3개 중 1개 PlayStation 2 Slimline PVR-802W Laser Replacement: 3 단계, 이미지 3개 중 2개 PlayStation 2 Slimline PVR-802W Laser Replacement: 3 단계, 이미지 3개 중 3개
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline PVR-802W Laser Replacement: 4 단계, 이미지 3개 중 1개 PlayStation 2 Slimline PVR-802W Laser Replacement: 4 단계, 이미지 3개 중 2개 PlayStation 2 Slimline PVR-802W Laser Replacement: 4 단계, 이미지 3개 중 3개
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline PVR-802W Laser Replacement, Remove screws and brackets: 5 단계, 이미지 3개 중 1개 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove screws and brackets: 5 단계, 이미지 3개 중 2개 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove screws and brackets: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the 2 philips screws
    • Remove the brackets on both sides with your tweezers.
  6. PlayStation 2 Slimline PVR-802W Laser Replacement, Remove silver rail: 6 단계, 이미지 3개 중 1개 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove silver rail: 6 단계, 이미지 3개 중 2개 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove silver rail: 6 단계, 이미지 3개 중 3개
    • If you got the same results as in the 1st photo, then proceed.
    • Take the silver rail and push it out *carefully* from the track.
    • Take the silver rail with your tweezers and pull it towards yourself to take it out. Be carefull, as it still attached to the laser, just guide it slowly towards yourself.
  7. PlayStation 2 Slimline PVR-802W Laser Replacement, Remove laser: 7 단계, 이미지 3개 중 1개 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove laser: 7 단계, 이미지 3개 중 2개 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove laser: 7 단계, 이미지 3개 중 3개
    • Take the laser with your hand, and till it like in the photo (to the back).
    • Open the ZIF connector. Be carefull not to break it, it can break easily. If you replace the laser, it won't matter, you can even practice how to open it and close it.
    • Take out the ribbon cable and remove the laser.
  8. PlayStation 2 Slimline PVR-802W Laser Replacement, Desoldering the anti-static security: 8 단계, 이미지 3개 중 1개 PlayStation 2 Slimline PVR-802W Laser Replacement, Desoldering the anti-static security: 8 단계, 이미지 3개 중 2개 PlayStation 2 Slimline PVR-802W Laser Replacement, Desoldering the anti-static security: 8 단계, 이미지 3개 중 3개
    • It's important to remove the anti-static security, otherwise it won't work! Some lasers come without the anti-static security.
    • You need a soldering station to DESOLDER the anti-static (if it's there), without de-soldering it, the laser could be busted!!
    • Remove the anti-static security. Use some copper wick to remove the solder.
    • When it looks like in the 3rd photo, you are good to.
    Ignorance probably on full display here: You need a soldering iron for this step, don’t you…? -_-
    And, what, I just rub the copper wick against it (after heating) until it looks like the second and third pictures?
    Arve Eriksson - 답글
    Sry if I didn’t make it clear enough :(. I’ll adjust this straight away. You need to desolder the anti-static security solder.
    koppie007 -
    IMPORTANT: use a soldering iron, tried it without, it broke
    Maximilian - 답글
    Got it, thanks. Done and dusted, and…
    It doesn’t light up when mounted in the console and power is turned on… Could I have done something wrong, or did I just get a dud laser? There are strange sounds, as well.
    Arve Eriksson -
    Thanks! I adjusted it straight away.
    koppie007 -
    @Arve, if it doesn’t light up and not doing anything, please check the disk lid sensors. There are 2 of them. 1 on the motherboard and the second one is located at the top of the power switch. Please check if they are both okay.
    koppie007 -
  9. PlayStation 2 Slimline PVR-802W Laser Replacement, Transfer holder: 9 단계, 이미지 3개 중 1개 PlayStation 2 Slimline PVR-802W Laser Replacement, Transfer holder: 9 단계, 이미지 3개 중 2개 PlayStation 2 Slimline PVR-802W Laser Replacement, Transfer holder: 9 단계, 이미지 3개 중 3개
    • Remove the single philips screw.
    • Transfer the holder to the new laser and fasten it again with the philips screw.
  10. PlayStation 2 Slimline PVR-802W Laser Replacement, Place the new laser in: 10 단계, 이미지 3개 중 1개 PlayStation 2 Slimline PVR-802W Laser Replacement, Place the new laser in: 10 단계, 이미지 3개 중 2개 PlayStation 2 Slimline PVR-802W Laser Replacement, Place the new laser in: 10 단계, 이미지 3개 중 3개
    • Take the new laser and open up the ZIF connector.
    • Place it back as shown in the 2nd photo.
    • Put everything back together. The 3rd picture show how it needs to be done!
결론
Do not forget to transfer the slider from the old laser to the new one!
다른 16명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
koppie007
회원 가입일: 08/22/13
25,981 평판
안내서 9개를 작성함
Protectors Of The Game Systems Protectors Of The Game Systems 회원
Community
6 회원들
안내서 35개를 작성함
댓글 9개
Thank you for caring enough to show us how to do this and for your time. You are appreciated.
Mark Sawyers - 답글
Hi Mark! No problem at all, happy to hear that I'm able to help you :)!!
koppie007 -
Where do you recommend getting the actual part? Looking for a reliable seller
Parker Ludwig - 답글
I am also looking for the best quality part. If I am going through the trouble of disassembling everything then I want to make sure I have a durable replacement. Excellent guide!
Jeremy B -
Thanks! Well, I'm afraid that the only option is to buy this from a Chinese webshop (AliExpress as example). You can't buy it on Amazon (as far as I looked it up). And getting one from another console which is not opened yet (original) is probably at the end of it's life time. I have some experience with a Chinese one, and they do work great so far!
koppie007 -
I think you're saying to make sure that the new laser doesn't have the antistatic security or to desolder it if it's there. Is that right?
Steve Murphy - 답글
Hi Steve!
Correct. If it’s there you need to desolder it. Otherwise it won’t work!
koppie007 -
where do you get good laser replacement on this day and & age ?
Louis Duquet - 답글
Atm you can get it from AliExpress. I honestly don’t know where to get it elsewhere. Those lasers are fine!
koppie007 -
댓글 쓰기
조회 통계:
지난 24시간: 36
지난 7일: 210
지난 30일: 996
전체 시간: 34,815
