주요 콘텐츠로 건너뛰기
PlayStation 3 AC Inlet Replacement
필요한 것
  1. PlayStation 3 AC Inlet Replacement, Smart Plate: 1 단계, 이미지 2개 중 1개 PlayStation 3 AC Inlet Replacement, Smart Plate: 1 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 AC Inlet Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 AC Inlet Replacement: 3 단계, 이미지 3개 중 1개 PlayStation 3 AC Inlet Replacement: 3 단계, 이미지 3개 중 2개 PlayStation 3 AC Inlet Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 AC Inlet Replacement: 4 단계, 이미지 1개 중 1개
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 AC Inlet Replacement, Top Cover: 5 단계, 이미지 1개 중 1개
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 AC Inlet Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 AC Inlet Replacement, Blu-ray Disc Drive: 7 단계, 이미지 1개 중 1개
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  8. PlayStation 3 AC Inlet Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. PlayStation 3 AC Inlet Replacement: 9 단계, 이미지 3개 중 1개 PlayStation 3 AC Inlet Replacement: 9 단계, 이미지 3개 중 2개 PlayStation 3 AC Inlet Replacement: 9 단계, 이미지 3개 중 3개
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
  10. PlayStation 3 AC Inlet Replacement, Motherboard Assembly: 10 단계, 이미지 1개 중 1개
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  11. PlayStation 3 AC Inlet Replacement: 11 단계, 이미지 2개 중 1개 PlayStation 3 AC Inlet Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  12. PlayStation 3 AC Inlet Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
  13. PlayStation 3 AC Inlet Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the control board bracket.
  14. PlayStation 3 AC Inlet Replacement: 14 단계, 이미지 2개 중 1개 PlayStation 3 AC Inlet Replacement: 14 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  15. PlayStation 3 AC Inlet Replacement: 15 단계, 이미지 1개 중 1개
    • Lift the motherboard assembly out of the lower case.
  16. PlayStation 3 AC Inlet Replacement, AC Inlet: 16 단계, 이미지 1개 중 1개
    • Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
  17. PlayStation 3 AC Inlet Replacement: 17 단계, 이미지 2개 중 1개 PlayStation 3 AC Inlet Replacement: 17 단계, 이미지 2개 중 2개
    • Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
    • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
  18. PlayStation 3 AC Inlet Replacement: 18 단계, 이미지 1개 중 1개
    • Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
결론
다른 24명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Walter Galan
701,778 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 20
지난 30일: 113
전체 시간: 36,063
