주요 콘텐츠로 건너뛰기
PlayStation 3 Control Board Replacement
필요한 것
  1. PlayStation 3 Control Board Replacement, Smart Plate: 1 단계, 이미지 2개 중 1개 PlayStation 3 Control Board Replacement, Smart Plate: 1 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Control Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Control Board Replacement: 3 단계, 이미지 3개 중 1개 PlayStation 3 Control Board Replacement: 3 단계, 이미지 3개 중 2개 PlayStation 3 Control Board Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Control Board Replacement: 4 단계, 이미지 1개 중 1개
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Control Board Replacement, Top Cover: 5 단계, 이미지 1개 중 1개
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Control Board Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Control Board Replacement, Control Board: 7 단계, 이미지 2개 중 1개 PlayStation 3 Control Board Replacement, Control Board: 7 단계, 이미지 2개 중 2개
    • Use your fingernail to flip up the retaining flap on the control board ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the control board ribbon cable out of its socket.
  8. PlayStation 3 Control Board Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
  9. PlayStation 3 Control Board Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the control board from the lower case.
결론
다른 21명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Walter Galan
706,103 평판
안내서 1,203개를 작성함
2가이드 댓글
I don't have the same ps3 as in the tutorial and my control board is broken. What can i do now?
McGarvey - 답글
Could anyone tell me if they would have the connection pin of this board, as I would like to fit it into a motherboard.
Allan Fabian Santos Souza - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 74
지난 30일: 218
전체 시간: 51,918
