주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation 3 Power Supply Replacement
필요한 것
  1. PlayStation 3 Power Supply Replacement, Smart Plate: 1 단계, 이미지 2개 중 1개 PlayStation 3 Power Supply Replacement, Smart Plate: 1 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Power Supply Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Power Supply Replacement: 3 단계, 이미지 3개 중 1개 PlayStation 3 Power Supply Replacement: 3 단계, 이미지 3개 중 2개 PlayStation 3 Power Supply Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Power Supply Replacement: 4 단계, 이미지 1개 중 1개
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Power Supply Replacement, Top Cover: 5 단계, 이미지 1개 중 1개
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Power Supply Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Power Supply Replacement, Memory Card Reader: 7 단계, 이미지 1개 중 1개
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  8. PlayStation 3 Power Supply Replacement: 8 단계, 이미지 2개 중 1개 PlayStation 3 Power Supply Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the memory card reader out of the PS3 enough to access its cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the memory card reader from the PS3.
  9. PlayStation 3 Power Supply Replacement, Power Supply: 9 단계, 이미지 1개 중 1개
    • Pull the DC-In cables toward the front of the PS3 to disconnect them from the power supply.
  10. PlayStation 3 Power Supply Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
  11. PlayStation 3 Power Supply Replacement: 11 단계, 이미지 1개 중 1개
    • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
  12. PlayStation 3 Power Supply Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the five 9 mm Phillips screws securing the power supply to the chassis.
  13. PlayStation 3 Power Supply Replacement: 13 단계, 이미지 1개 중 1개
    • Lift the power supply upward from its front edge to disconnect it from the posts attached to the logic board.
    • Remove the power supply.
결론
다른 49명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Walter Galan
709,575 평판
안내서 1,203개를 작성함
6가이드 댓글
This is for the 60gb version. As there is no card reader in the 80gb i replaced the power supply in and some of the psu screws were in a slightly different place. But a very good guide.
Craig Taylor - 답글 공유
I have a Ps3 that was bought in America. The power supply is different to ours here in South Africa (Cape Town). A friend who gave me the Ps3 also had an external power supply built so that it can be used here. It's been working for years but now I have that green light thingy going. I've removed the disc that was in it and thought it may have been inserted incorrectly. Now that I have seen your tutorial I will definitely check if it's the power supply or mother board. Thank you.
patrickms - 답글 공유
CAN I HAVE THE MANUAL MY RED LIGHT IS ON ALSO DIRECT ME TO A GOOD PLACE FOR REPAIRS IN ACCRA GHANA EMAIL honmante54@yahoo.com thank you
honmante54 - 답글 공유
why do your consoles have this red light on why do something about it
honmante54 - 답글 공유
Hi I need a good fix store in Greece for ps3 in order to replace my power supply
Manos Kallimanis - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 82
지난 30일: 340
전체 시간: 117,997
