소개
Use this guide to replace your heat sink. It is essential to apply a new layer of thermal paste during reassembly.
필요한 것
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
Pull the AC-In cables upward to remove the AC inlet from the lower case.
다른 42명이 해당 안내서를 완성하였습니다.
댓글 7개
Thanks for this guide
Hi, is the heatsink that makes contact with the cpu die aluminium? I think I might have repasted it with liquid metal… Thanks!
