주요 콘텐츠로 건너뛰기
PlayStation 3 Super Slim Laser Lens Replacement
필요한 것
동영상 지침
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 4개
1. Do not loosen any screws the guide bars sit on. They are factory set at the correct height.
2. It is only necessary to remove the clips on the drive motor side of the guide bar. The laser will come right off the worm gear and you can remove the laser.
Wade - 답글
Hi, i have a ps3 super slim CECH-4201C and it stopped playing any disk i put in it. So i wanna change it but my lens is a single lens and all the ones i can find is double, will it still work for mine? Also where can i get a single lens and which is better. The console is 500gb came with "The last of us". Thanks. Hope to hear from you soon.
temidayoabayomizannu - 답글
Too advanced for me to do. Whenever I take things apart I mess them up. Once took a PS3 fat apart and could never get it back together. If I sent it to Playstation they wouldn't delete my saved data right?
konekodemon - 답글
I am replacing the optical drive in my console. But didn't note where the drive ribbon was positioned!? Every video I have found, they just pop right in...my original and replacement drives, have larger receptacles than the ribbon it self. There are at least 5 pins, that don't have (potentially) anything connecting them, to the ribbon. I don't want to randomly place the ribbon in one of the possible (7?) positions and fry something in the process...so where do I connect the smaller ribbon?!
Robert Shelton - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 28
지난 30일: 129
전체 시간: 38,745
