주요 콘텐츠로 건너뛰기
PlayStation 3 Wi-Fi/Bluetooth Board Replacement
필요한 것
  1. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Smart Plate: 1 단계, 이미지 2개 중 1개 PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Smart Plate: 1 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 3 단계, 이미지 3개 중 1개 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 3 단계, 이미지 3개 중 2개 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 4 단계, 이미지 1개 중 1개
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Top Cover: 5 단계, 이미지 1개 중 1개
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Memory Card Reader: 7 단계, 이미지 1개 중 1개
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  8. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 8 단계, 이미지 2개 중 1개 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the memory card reader out of the PS3 enough to access its cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the memory card reader from the PS3.
  9. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Wi-Fi/Bluetooth Board: 9 단계, 이미지 1개 중 1개
    • If necessary, peel the memory card reader ribbon cable off the Wi-Fi/Bluetooth board.
  10. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 10 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the Wi-Fi antenna connector up from its socket on the Wi-Fi/Bluetooth board.
  11. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 11 단계, 이미지 2개 중 1개 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 11 단계, 이미지 2개 중 2개
    • Use your fingernail to flip up the retaining flap on the Wi-Fi/Bluetooth ribbon cable socket.
    • Pull the Wi-Fi/Bluetooth ribbon cable out of its socket.
  12. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the four 9 mm Phillips screws securing the Wi-Fi/Bluetooth board to the chassis.
  13. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the Wi-Fi/Bluetooth board from the PS3, minding any cables that may get caught.
결론
다른 25명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Walter Galan
701,723 평판
안내서 1,203개를 작성함
4가이드 댓글
Note: Only the first 2 generations of PS3 fats have removable Wifi/BT cards. If you have a third generation fat (VER-100 motherboard or later) the Wifi/BT chips are integrated into the board and thereby NOT removable.
Kevin Kwan - 답글
does anybody know how many pins there are on the data ribbon / flex cable of the Wifi / Bluetooth board and Card Reader in the 60gb Model? It would be a great help! Thanx
yasien teladia - 답글
I have a PS3 Slim 2501b can I still use this technique to change my Bluetooth
Kathleen Pereira - 답글
No you can't
J P -
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 112
지난 30일: 471
전체 시간: 120,405
