주요 콘텐츠로 건너뛰기
PlayStation Move Rumble Motor Replacement
필요한 것
  1. PlayStation Move Rumble Motor Replacement, Case: 1 단계, 이미지 1/2 PlayStation Move Rumble Motor Replacement, Case: 1 단계, 이미지 2/2
    • Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
  2. PlayStation Move Rumble Motor Replacement: 2 단계, 이미지 1/3 PlayStation Move Rumble Motor Replacement: 2 단계, 이미지 2/3 PlayStation Move Rumble Motor Replacement: 2 단계, 이미지 3/3
    • Pinch the sides of the back panel to remove it and set it aside.
  3. PlayStation Move Rumble Motor Replacement: 3 단계, 이미지 1/2 PlayStation Move Rumble Motor Replacement: 3 단계, 이미지 2/2
    • Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
  4. PlayStation Move Rumble Motor Replacement: 4 단계, 이미지 1/2 PlayStation Move Rumble Motor Replacement: 4 단계, 이미지 2/2
    • Push the Lithium Ion battery from its slot to remove it.
    • Be mindful not to damage the wires or wired components, as the battery will still be attached via its connector.
  5. PlayStation Move Rumble Motor Replacement: 5 단계, 이미지 1/1
    • Unscrew the 9mm screw in the battery slot with a PH #00 screwdriver.
  6. PlayStation Move Rumble Motor Replacement: 6 단계, 이미지 1/2 PlayStation Move Rumble Motor Replacement: 6 단계, 이미지 2/2
    • Using a plastic opening tool, carefully pry the rumble motor free.
  7. PlayStation Move Rumble Motor Replacement: 7 단계, 이미지 1/1
    • Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
  8. PlayStation Move Rumble Motor Replacement: 8 단계, 이미지 1/3 PlayStation Move Rumble Motor Replacement: 8 단계, 이미지 2/3 PlayStation Move Rumble Motor Replacement: 8 단계, 이미지 3/3
    • Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
  9. PlayStation Move Rumble Motor Replacement: 9 단계, 이미지 1/2 PlayStation Move Rumble Motor Replacement: 9 단계, 이미지 2/2
    • Using your fingers, carefully pry the square green piece beneath the battery slot free.
    • It is attached via white ribbons which need to be kept intact.
  10. PlayStation Move Rumble Motor Replacement: 10 단계, 이미지 1/3 PlayStation Move Rumble Motor Replacement: 10 단계, 이미지 2/3 PlayStation Move Rumble Motor Replacement: 10 단계, 이미지 3/3
    • Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
    • Lift the rectangular piece from its slot to free it.
  11. PlayStation Move Rumble Motor Replacement: 11 단계, 이미지 1/3 PlayStation Move Rumble Motor Replacement: 11 단계, 이미지 2/3 PlayStation Move Rumble Motor Replacement: 11 단계, 이미지 3/3
    • Carefully lift the entire circuit board from the black plastic encasing it.
    • Take extra care not to damage any of the wired components.
  12. PlayStation Move Rumble Motor Replacement, Rumble Motor: 12 단계, 이미지 1/1
    • Using a soldering iron, carefully desolder the wires from the board. For help with desoldering, please check out this guide: How To Solder and Desolder Connections
    • In order to install the new rumble motor, you must solder the wires of the new motor to the circuit board.
결론
Sarah Shand
회원 가입일: 02/20/17
1,912 평판
안내서 7개 작성하였습니다
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G1
3 회원들
안내서 13개 작성하였습니다
댓글 한 개
Step 7, there are 2 screws at the top near the white spherical piece holding the PCB on place that also need to be removed before you can lift it out
Steve Massart - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 18
30일 전: 31
전체 시간: 1,516
