소개
The USB is an important part of the PlayStation Move controller. This guide will help you to remove and replace.
부품
지정된 부품이 없습니다.
At the end of the circuit board, you should see a small silver connector port (this is the USB).
Using a soldering iron, carefully desolder the port from the board. For help with desoldering, please reference this guide: How To Solder and Desolder Connections
다른 한 분이 해당 안내서를 완성하였습니다.
