이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
Using your fingers, carefully pry the square green piece beneath the battery slot free.
Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
Lift the rectangular piece from its slot to free it.
Carefully lift the entire circuit board from the black plastic encasing it.
At the end of the circuit board, you should see a small silver connector port (this is the USB).
Using a soldering iron, carefully desolder the port from the board. For help with desoldering, please reference this guide: How To Solder and Desolder Connections
다른 2명이 해당 안내서를 완성하였습니다.
