주요 콘텐츠로 건너뛰기
PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+)
필요한 것
  1. 이 단계에 사용된 도구:
    Essential Electronics Toolkit
    $29.95
  2. PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Is your system recoverable?: 2 단계, 이미지 1개 중 1개
    • Before starting, make sure you have a die cast laser. Plastic lasers are not repairable.
    • If your laser is plastic: You must replace the laser due to uneven wear.
    • If you have a Die cast laser, this fix may improve the read rate. However, this is an age based failure. Note: In some cases, the laser resistance will need to be adjusted.
  3. PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Opening the system: 3 단계, 이미지 3개 중 1개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Opening the system: 3 단계, 이미지 3개 중 2개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Opening the system: 3 단계, 이미지 3개 중 3개
    • EET owners: Your kit has this bit. No purchase needed.
    • Remove the 6 screws from the bottom of the PlayStation. Use a Phillips #2 screwdriver.
    • Lift the top cover off.
  4. PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Disconnect the laser: 4 단계, 이미지 3개 중 1개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Disconnect the laser: 4 단계, 이미지 3개 중 2개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Disconnect the laser: 4 단계, 이미지 3개 중 3개
    • Disconnect the laser from the system.
  5. PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Repair sanity check: 5 단계, 이미지 3개 중 1개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Repair sanity check: 5 단계, 이미지 3개 중 2개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Repair sanity check: 5 단계, 이미지 3개 중 3개
    • With the laser removed from the system, remove the 2 Phillips PH1 screws. Check if the laser is plastic.
    • If the laser is plastic, it cannot be repaired and must be replaced. The example shown can be adjusted.
  6. PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Adjust the motor trimpot: 6 단계, 이미지 3개 중 1개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Adjust the motor trimpot: 6 단계, 이미지 3개 중 2개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Adjust the motor trimpot: 6 단계, 이미지 3개 중 3개
    • Only adjust this enough to reliably read games and music CDs again. If the speed is too slow, the laser may physically "burn" your games, albeit very unlikely unless you adjust the laser trimpot on the mainboard.
    • Consider anything less then a 80-90% read rate a failure. These are hard to recover reliably.
    • Before starting, mark the original adjustment point and write down the factory setting as tested. It will be difficult to take it back to stock without this information.
    • Adjust the trimpot incrementally using a Phillips PH1 or other compatible bit. Do this until the laser is reading games more consistently.
  7. PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Test the repaired system: 7 단계, 이미지 2개 중 1개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Test the repaired system: 7 단계, 이미지 2개 중 2개
    • If possible, test on a known good system first.
    • Improving the read percentage: If you are not happy with the results, keep adjusting the motor. Repeat until you are happy with the passing read rate, or the motor doesn't spin.
    • If you see the Insert PlayStation CD-ROM screen, the motor is running slow. Adjust the speed to be faster.
    • Partially reassemble the system and test it. If it is sufficient, reassemble the system.
    • To test the read percentage, get a few known good games and see which ones load. A minimum of 5 test games is recommended. Only adjust the laser again after each full test is done.
    • If the game loads, test play the system for a few minutes to check the stability. Important: Some early revisions have FMV issues - THIS IS EXPECTED.
  8. PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Test data - control system (SCPH-101): 8 단계, 이미지 2개 중 1개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Test data - control system (SCPH-101): 8 단계, 이미지 2개 중 2개
    • Control system results
  9. PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Test data - repaired system (SCPH-5501): 9 단계, 이미지 2개 중 1개 PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+), Test data - repaired system (SCPH-5501): 9 단계, 이미지 2개 중 2개
    • Repaired SCPH-5501 results
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nick
회원 가입일: 11/10/09
98,698 평판
안내서 63개를 작성함
3가이드 댓글
Do you have the specifics as to the spacers and trimpot adjustment when using a new KSM-440BAM (with extension cable if needed) on either SCPH-1001 or SCPH-5501?
leafybye - 답글
No - I do not.
Nick -
Hello, I recently attempted to replace my weak laser in my 5501 with a 440BAM and it did not work, I even tried putting back the old laser but it wouldn't work again at all no motor spin or anything. Any ideas as to what I'm doing wrong or how to fix? Thanks!
James Whitson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 39
지난 30일: 175
전체 시간: 27,665
