주요 콘텐츠로 건너뛰기
PlayStation Start and Select Buttons Replacement
필요한 것
  1. PlayStation Start and Select Buttons Replacement, Start and Select Buttons: 1 단계, 이미지 1개 중 1개
    • Before you begin, unplug your controller and console to avoid accidentally turning it on during disassembly.
  2. PlayStation Start and Select Buttons Replacement: 2 단계, 이미지 3개 중 1개 PlayStation Start and Select Buttons Replacement: 2 단계, 이미지 3개 중 2개 PlayStation Start and Select Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the five 7.2 mm screws securing the rear cover.
  3. PlayStation Start and Select Buttons Replacement: 3 단계, 이미지 3개 중 1개 PlayStation Start and Select Buttons Replacement: 3 단계, 이미지 3개 중 2개 PlayStation Start and Select Buttons Replacement: 3 단계, 이미지 3개 중 3개
    • Gently push the rear cover towards the front of the #2 trigger buttons.
    • Lift the rear cover.
    • The #2 trigger buttons may come off when removing the cover.
  4. PlayStation Start and Select Buttons Replacement: 4 단계, 이미지 2개 중 1개 PlayStation Start and Select Buttons Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the battery and set it beside the controller, with care not to strain the wires.
    • Use a Phillips #1 screwdriver to remove the single 7.2 mm screw securing the motherboard.
  5. PlayStation Start and Select Buttons Replacement: 5 단계, 이미지 2개 중 1개 PlayStation Start and Select Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Unclip the vibrating motors.
    • Be careful not to break the black and red wires connected to the motherboard. They are very fragile!
  6. PlayStation Start and Select Buttons Replacement: 6 단계, 이미지 2개 중 1개 PlayStation Start and Select Buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Lift off the plastic housing holding the motherboard, battery, and vibrating motors.
  7. PlayStation Start and Select Buttons Replacement: 7 단계, 이미지 3개 중 1개 PlayStation Start and Select Buttons Replacement: 7 단계, 이미지 3개 중 2개 PlayStation Start and Select Buttons Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the rubber buttons with a pair of tweezers.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Gabriel Ortiz
회원 가입일: 03/18/22
193 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 28
지난 30일: 67
전체 시간: 2,275
