소개
If the device loses charge more quickly than expected, or fails to charge, consider using this guide to replace it.
필요한 것
Flip the device so that the screen faces down, with the back facing up.
Unscrew the four screws with a PH000 screwdriver.
Grip the the battery by hand.
Lift the battery, by hand, to remove it from the glue and panel.
Desolder the wires from the motherboard. For detailed information, refer to the Solder and Desolder guide.
다른 한 분이 해당 안내서를 완성하였습니다.
