소개
This replacement process calls for soldering electronic components and smelly adhesive. Attempt if comfortable working with a soldering gun and fine details. For more information about desoldering, see this helpful guide.
필요한 것
Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver to turn them counterclockwise.
Desolder the following components from the motherboard.
Desolder from the motherboard the red wire that connects to the speaker unit.
Desolder from the motherboard the black wire that connects to the speaker unit.
Desolder from the motherboard the gray wire that runs along the edge of the device.
The motherboard will now be detached from any wires connecting to the device.
Use tweezers to unstick the medium width yellow ribbon cable from the motherboard
Use a small plastic opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
The motherboard will now be detached from any ribbon cables connecting to the device.
다른 한 분이 해당 안내서를 완성하였습니다.
