소개
This replacement process calls for soldering electronic components and very steady hands. For more information about desoldering, take a look at this helpful guide.
필요한 것
Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning the screws counterclockwise.
이 단계에 사용된 도구:Tweezers$4.99
Desolder the following components from the motherboard.
Desolder from the motherboard the red wire that connects to the speaker unit.
Desolder from the motherboard the black wire that connects to the speaker unit.
Desolder from the motherboard the gray wire that runs along the edge of the device.
Desolder from the motherboard the red wire that connects to the battery unit.
Desolder from the motherboard the black wire that connects to the battery unit.
The motherboard will now be detached from any wires connecting to the device.
Use tweezers to unstick the medium width yellow ribbon cable from the motherboard.
Use a small plastic opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
The motherboard and battery will now be detached from any ribbon cables connecting to the device.
