주요 콘텐츠로 건너뛰기
Polaroid i835 LCD Replacement
필요한 것
  1. Polaroid i835 LCD Replacement, LCD: 1 단계, 이미지 1/3 Polaroid i835 LCD Replacement, LCD: 1 단계, 이미지 2/3 Polaroid i835 LCD Replacement, LCD: 1 단계, 이미지 3/3
    • remove the batteries, the memory card as well as the carrying strip (if so equipped).
    • Remove the 2 screws on the right hand side.
    • Remove the 2 screws on the left hand side.
  2. Polaroid i835 LCD Replacement: 2 단계, 이미지 1/3 Polaroid i835 LCD Replacement: 2 단계, 이미지 2/3 Polaroid i835 LCD Replacement: 2 단계, 이미지 3/3
    • One more screw on the bottom, underneath the manufacturer's label.
    • Start spitting the case from the battery compartment. You can use a plastic opening tool, or your finger nails. It does bind a bit at the USB port side, but will separate pretty quick.
    • With the back removed, the large LCD becomes immediately visible. There are no fasteners, it just rests inside the tray.
  3. Polaroid i835 LCD Replacement: 3 단계, 이미지 1/2 Polaroid i835 LCD Replacement: 3 단계, 이미지 2/2
    • Lift the LCD out of the tray and move it to the right of the tray. The cable is still attached to the logic board via a latch.
    • With the plastic opening tool, or your fingernails, gently flip the latch to the left side. This will free the LCD cable. Remove the LCD and install your new one.
결론
oldturkey03
회원 가입일: 09/29/10
782,480 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 544개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 1,110
