이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
remove the batteries, the memory card as well as the carrying strip (if so equipped).
Remove the 2 screws on the right hand side.
Remove the 2 screws on the left hand side.
One more screw on the bottom, underneath the manufacturer's label.
Start spitting the case from the battery compartment. You can use a plastic opening tool, or your finger nails. It does bind a bit at the USB port side, but will separate pretty quick.
With the back removed, the large LCD becomes immediately visible. There are no fasteners, it just rests inside the tray.
Lift the LCD out of the tray and move it to the right of the tray. The cable is still attached to the logic board via a latch.
With the plastic opening tool, or your fingernails, gently flip the latch to the left side. This will free the LCD cable. Remove the LCD and install your new one.
