주요 콘텐츠로 건너뛰기
Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement
필요한 것
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: 1 단계, 이미지 1/3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: 1 단계, 이미지 2/3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: 1 단계, 이미지 3/3
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Screws to Base Plate: 2 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: 3 단계, 이미지 1/3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: 3 단계, 이미지 2/3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: 3 단계, 이미지 3/3
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
  4. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing the Screws from the Charger Plate: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two 5mm screws from the metal plate.
  5. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing the Plate: 5 단계, 이미지 1/1
    • Grip the metal plate and pull towards you.
    • You may need to wiggle the plate back and forth gently to loosen it from its housing.
  6. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Screw from Base Cover: 6 단계, 이미지 1/1
    • Use the Philips #00 screwdriver to remove the four 6mm screws from the base cover.
  7. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Separating Charge Plate from Base Cover: 7 단계, 이미지 1/1
    • Gently pull the charge plate away from the rest of the base and separate the two pieces of the charge plate.
  8. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Glue from Wires: 8 단계, 이미지 1/2 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Glue from Wires: 8 단계, 이미지 2/2
    • Use the spudger to gently scrape the glue away from the wire connections.
    • If the spudger is not adequate, try using the tweezers to pull the glue away before scraping.
  9. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Desoldering the Wire Connections: 9 단계, 이미지 1/1
    • Use the soldering station to desolder the wire connections.
    • For further instructions on using the soldering station click here.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jay Gunter
회원 가입일: 10/27/14
378 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 6
전체 시간: 182
