주요 콘텐츠로 건너뛰기
Porter-Cable PCC710B Housing and Cover Replacement
필요한 것
  1. Porter-Cable PCC710B Housing and Cover Replacement, Lever assembly: 1 단계, 이미지 1/1
    • Place the tool on its side so the orange and white warning label barcodes are facing up.
    • The lever and battery base of the tool should point toward you.
  2. Porter-Cable PCC710B Housing and Cover Replacement: 2 단계, 이미지 1/3 Porter-Cable PCC710B Housing and Cover Replacement: 2 단계, 이미지 2/3 Porter-Cable PCC710B Housing and Cover Replacement: 2 단계, 이미지 3/3
    • Use a 5.5 mm nut driver to unscrew the Hex nut.
    • If the Hex nut is not unscrewing easily- you can use a 3 mm Hex head screwdriver to hold the other side of the screw still.
  3. Porter-Cable PCC710B Housing and Cover Replacement: 3 단계, 이미지 1/1
    • Flip the tool over and remove the black screw holding the tool together.
    • Get a good grip on the screw by using pliers to pull the screw out of the tool.
  4. Porter-Cable PCC710B Housing and Cover Replacement: 4 단계, 이미지 1/3 Porter-Cable PCC710B Housing and Cover Replacement: 4 단계, 이미지 2/3 Porter-Cable PCC710B Housing and Cover Replacement: 4 단계, 이미지 3/3
    • Pinch the lever with your fingers and pull it up and away from the tool. The lever pops right off! You can squeeze on the lever, and it will come off just as easily.
    • When replacing your new lever assembly, make sure the black torsion (the black staple-like hinge) is oriented correctly.
  5. Porter-Cable PCC710B Housing and Cover Replacement, Housing: 5 단계, 이미지 1/3 Porter-Cable PCC710B Housing and Cover Replacement, Housing: 5 단계, 이미지 2/3 Porter-Cable PCC710B Housing and Cover Replacement, Housing: 5 단계, 이미지 3/3
    • Lay the tool on its side so that the grey and orange warning labels are facing up upwards.
    • Use the JIS #1 screwdriver to remove the 10 screws holding the tool together.
  6. Porter-Cable PCC710B Housing and Cover Replacement: 6 단계, 이미지 1/3 Porter-Cable PCC710B Housing and Cover Replacement: 6 단계, 이미지 2/3 Porter-Cable PCC710B Housing and Cover Replacement: 6 단계, 이미지 3/3
    • Lift the case off to access the internals of the tool.
결론
Alex Zapata
회원 가입일: 09/19/22
665 평판
안내서 7개 작성하였습니다
Austin Community College, Team 13-3, Watkins Fall 2022 Austin Community College, Team 13-3, Watkins Fall 2022 회원
AUSTINCC-WATKINS-F22S13G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 146
