주요 콘텐츠로 건너뛰기
Power Mac G4 Cube Hard drive Replacement
필요한 것
  1. Power Mac G4 Cube Hard drive Replacement, Outer Case: 1 단계, 이미지 3개 중 1개 Power Mac G4 Cube Hard drive Replacement, Outer Case: 1 단계, 이미지 3개 중 2개 Power Mac G4 Cube Hard drive Replacement, Outer Case: 1 단계, 이미지 3개 중 3개
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Hard drive Replacement: 2 단계, 이미지 2개 중 1개 Power Mac G4 Cube Hard drive Replacement: 2 단계, 이미지 2개 중 2개
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Hard drive Replacement: 3 단계, 이미지 1개 중 1개
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Hard drive Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Hard drive Replacement, Hard drive: 5 단계, 이미지 1개 중 1개
    • Lift Airport slot.
  6. Power Mac G4 Cube Hard drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the power cord from the hard drive.
    • Remove the IDE cable from the hard drive.
    • Grip the sides of the hard drive and slowly pull outward.
  7. Power Mac G4 Cube Hard drive Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the three top screws of the hard drive use a T8 bit and remove the heat sink.
    • Carefully slide the hard drive to the open side (side without the IDE and power cables) to remove the drive.
    • Turn the drive over, remove the sled rail with a T10 driver for its two screws. Transfer the rail to the same side on the new drive.
    • Insert new hard drive.
결론
다른 21명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Ryan Chun
회원 가입일: 06/24/10
1,076 평판
안내서 7개를 작성함
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G7
5 회원들
안내서 21개를 작성함
1가이드 댓글
Strictly speaking, steps 2 through 4 aren’t necessary: you can just unscrew the heatsink from the hard drive, as in step 7, and carefully lift it out (I found that tilting it toward the optical drive and then pivoting it out worked).
bobtheflyingsquirrel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 71
전체 시간: 19,208
