주요 콘텐츠로 건너뛰기
Power Mac G4 Quicksilver Central Processing Unit Replacement
필요한 것
  1. Power Mac G4 Quicksilver Central Processing Unit Replacement, Opening the case: 1 단계, 이미지 1개 중 1개
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Central Processing Unit Replacement: 2 단계, 이미지 2개 중 1개 Power Mac G4 Quicksilver Central Processing Unit Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Central Processing Unit Replacement: 3 단계, 이미지 1개 중 1개
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Central Processing Unit Replacement, Video Adapter: 4 단계, 이미지 1개 중 1개
    • This is your Power Mac G4's video adapter.
  5. Power Mac G4 Quicksilver Central Processing Unit Replacement: 5 단계, 이미지 1개 중 1개
    • Start by removing the screw holding the card to the chassis as shown.
  6. Power Mac G4 Quicksilver Central Processing Unit Replacement: 6 단계, 이미지 1개 중 1개
    • Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
  7. Power Mac G4 Quicksilver Central Processing Unit Replacement: 7 단계, 이미지 2개 중 1개 Power Mac G4 Quicksilver Central Processing Unit Replacement: 7 단계, 이미지 2개 중 2개
    • With the tab and screw removed, lift the card straight out.
    • When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
  8. Power Mac G4 Quicksilver Central Processing Unit Replacement, Central Processing Unit: 8 단계, 이미지 1개 중 1개
    • First you want to remove the fan. Remove the two screws on the back of the computer in the upper left hand corner.
  9. Power Mac G4 Quicksilver Central Processing Unit Replacement: 9 단계, 이미지 2개 중 1개 Power Mac G4 Quicksilver Central Processing Unit Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the fan unit by pulling straight up and out.
    • Be carful not to rip out the cord still attached to the motherboard. Remove it gently.
  10. Power Mac G4 Quicksilver Central Processing Unit Replacement: 10 단계, 이미지 2개 중 1개 Power Mac G4 Quicksilver Central Processing Unit Replacement: 10 단계, 이미지 2개 중 2개
    • You need detach the heat sink from the CPU. Locate the four clamps holding it down, two on each side.
    • Taking off the clamps can be difficult. Use a screwdriver to push down on the top of the clip. Then insert a spudger below the heat sink to pull it away from the board, releasing the heat sink.
  11. Power Mac G4 Quicksilver Central Processing Unit Replacement: 11 단계, 이미지 2개 중 1개 Power Mac G4 Quicksilver Central Processing Unit Replacement: 11 단계, 이미지 2개 중 2개
    • Pull the heat sink up and off of the CPU.
  12. Power Mac G4 Quicksilver Central Processing Unit Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the four screws holding the CPU to the motherboard.
  13. Power Mac G4 Quicksilver Central Processing Unit Replacement: 13 단계, 이미지 2개 중 1개 Power Mac G4 Quicksilver Central Processing Unit Replacement: 13 단계, 이미지 2개 중 2개
    • Now you can remove the CPU by pulling it straight up from the motherboard.
    • Be very careful when you detach the CPU. There is a connector that has hundreds of little prongs. You must not bend or break any of them! Be extremely careful.
  14. Power Mac G4 Quicksilver Central Processing Unit Replacement: 14 단계, 이미지 1개 중 1개
    • You can now replace the CPU.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ryan Bylard
회원 가입일: 01/20/10
1,325 평판
안내서 5개를 작성함
Cal Poly, Team 14-41, Regan Winter 2010 Cal Poly, Team 14-41, Regan Winter 2010 회원
CPSU-REGAN-W10S14G41
4 회원들
안내서 27개를 작성함
1가이드 댓글
Removing graphics (video) card is not necessary. Also, removing the clips which retain heat-sink can be accomplished by using a flat-blade (-) screwdriver to carefully pry them from the finned aluminum assembly. Other than these two suggestions, guide is succinct and accurate.
analogcd - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 33
전체 시간: 12,119
