주요 콘텐츠로 건너뛰기
PowerA Fusion Controller For Xbox One Analog Stick Replacement
필요한 것
  1. PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: 1 단계, 이미지 3개 중 1개 PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: 1 단계, 이미지 3개 중 2개 PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: 1 단계, 이미지 3개 중 3개
    • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
    • Lift off the two bottom grip covers of the controller.
  2. PowerA Fusion Controller For Xbox One Analog Stick Replacement: 2 단계, 이미지 2개 중 1개 PowerA Fusion Controller For Xbox One Analog Stick Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the remaining (2) two 9.2mm screws holding the back cover with a JIS #1 screwdriver.
    • Carefully lift and remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Analog Stick Replacement: 3 단계, 이미지 3개 중 1개 PowerA Fusion Controller For Xbox One Analog Stick Replacement: 3 단계, 이미지 3개 중 2개 PowerA Fusion Controller For Xbox One Analog Stick Replacement: 3 단계, 이미지 3개 중 3개
    • Carefully remove the (5) five 9.2mm screws holding the motherboard with a JIS #1 screwdriver.
    • Lift the motherboard and rest it face up to the right of the controller front plate.
  4. PowerA Fusion Controller For Xbox One Analog Stick Replacement: 4 단계, 이미지 2개 중 1개 PowerA Fusion Controller For Xbox One Analog Stick Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
    • Remove the motherboard from the face plate of the controller.
  5. PowerA Fusion Controller For Xbox One Analog Stick Replacement: 5 단계, 이미지 2개 중 1개 PowerA Fusion Controller For Xbox One Analog Stick Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tweezers to unclip the (4) four metal teeth of the analog stick.
    • Use the soldering iron and desoldering braid to desolder the analog stick sensor module from the back of the motherboard.
    • Place the new analog stick sensor module and solder it back.
    • Use the 연결부 납땜 및 납제거 방법 guide on iFixit to help in desoldering and soldering the analog stick sensor module.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Marjan Mehedi
회원 가입일: 09/27/17
182 평판
안내서 1개를 작성함
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G4
4 회원들
안내서 7개를 작성함
3가이드 댓글
Hi I’m looking those analog stick but I’m only finding the plastic and they are to big they are called different or something ?
Jose nobkes - 답글
Have you found a replacement yet? I ran into the same problem a couple of months ago, the potenciometers that I ordered did not fit into the motherboard. I even tried some other ones from a generic USB controler to no avail. Manufacturers do not report the sizes of the potenciometers, so it’s a bet everytime. I yet have to find a potentiometer that fits…
Franco Valdés -
Any joy on purchasing these
Mike Jones -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 39
지난 30일: 147
전체 시간: 17,518
