주요 콘텐츠로 건너뛰기
PowerA Fusion Controller For Xbox One Headphone Jack Replacement
필요한 것
  1. PowerA Fusion Controller For Xbox One Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 3개 중 1개 PowerA Fusion Controller For Xbox One Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 3개 중 2개 PowerA Fusion Controller For Xbox One Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 3개 중 3개
    • Remove the (9) nine 9.2mm screws (circled in red) with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Headphone Jack Replacement: 2 단계, 이미지 2개 중 1개 PowerA Fusion Controller For Xbox One Headphone Jack Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the (2) two 9.2mm screws (circled in red) with a JIS #1 screwdriver.
    • Remove the back cover of the controller as seen in image (2) two.
  3. PowerA Fusion Controller For Xbox One Headphone Jack Replacement: 3 단계, 이미지 2개 중 1개 PowerA Fusion Controller For Xbox One Headphone Jack Replacement: 3 단계, 이미지 2개 중 2개
    • Desolder the soldered joints that are connecting the headphone jack to the motherboard (Circled in red).
    • This guide will show you how to solder and desolder connections.
    • Remove the headphone jack and put it aside.
결론
작성자
7다른 기여자 명과 함께
Andrea
회원 가입일: 09/26/17
668 평판
안내서 4개를 작성함
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G4
4 회원들
안내서 7개를 작성함
2가이드 댓글
Has this been proven to work? Thanks!
Luis Lujan - 답글
real help full its like having a broken down car and a video online saying “open bonnet and fix car” no mention of where you can get those parts ie the most important bit the parts ie the female jack port !!!! other than not for sale !! blinding
James Price - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 45
전체 시간: 7,809
