주요 콘텐츠로 건너뛰기
PowerA Fusion Controller For Xbox One Vibration Motors Replacement
필요한 것
  1. PowerA Fusion Controller For Xbox One Vibration Motors Replacement, Vibration Motors: 1 단계, 이미지 1/3 PowerA Fusion Controller For Xbox One Vibration Motors Replacement, Vibration Motors: 1 단계, 이미지 2/3 PowerA Fusion Controller For Xbox One Vibration Motors Replacement, Vibration Motors: 1 단계, 이미지 3/3
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Vibration Motors Replacement: 2 단계, 이미지 1/2 PowerA Fusion Controller For Xbox One Vibration Motors Replacement: 2 단계, 이미지 2/2
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Vibration Motors Replacement: 3 단계, 이미지 1/2 PowerA Fusion Controller For Xbox One Vibration Motors Replacement: 3 단계, 이미지 2/2
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
결론
Andrea
회원 가입일: 09/26/17
623 평판
안내서 4개 작성하였습니다
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 9
전체 시간: 706
