소개
Waffle irons are equipped with a thermal fuse that disconnect the circuit once a certain temperature is reached to ensure the appliance does not become a hazard to users. A thermal fuse is a single-use device, and once it burns out the waffle iron will not function. This guide demonstrates how to replace a burnt out thermal fuse and return the waffle iron to working order.
필요한 것
Remove the four 0.7 mm screws that keep the cover of the wiring and thermal fuse in place using a #2 Phillips-head screwdriver.
Use two pairs of needle-nosed pliers to pull the fuse out of the conduction bearing. Firmly grasp one end of the thermal fuse with one set of pliers and the conduction bearing it is connected to and pull them apart.
Remove the insulation from the thermal fuse and pull the other end of the thermal fuse out of the circuit in the same way.
To reassemble your device, follow steps 1 and 2 in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 4개
Won't the solder melt when you turn on the waffle iron? Duh
Yeah, I think you need to clamp or spot-weld?
