주요 콘텐츠로 건너뛰기
Programmeer het automatisch opstarten van je pc
    • Wanneer je je computer opstart, druk je op de Del- of F2-toets, afhankelijk van je moederbord
  1. Programmeer het automatisch opstarten van je pc, Navigate to the Alimentation tab: 2 단계, 이미지 1개 중 1개
    • With the arrow keys, move the header towards the Alimentation tab.
  2. Programmeer het automatisch opstarten van je pc, APM Configuration: 3 단계, 이미지 1개 중 1개
    • Once again with the arrow keys, higlight the APM Configuration option and press Enter.
  3. Programmeer het automatisch opstarten van je pc, RTC Configuration: 4 단계, 이미지 3개 중 1개 Programmeer het automatisch opstarten van je pc, RTC Configuration: 4 단계, 이미지 3개 중 2개 Programmeer het automatisch opstarten van je pc, RTC Configuration: 4 단계, 이미지 3개 중 3개
    • Navigate to the Power On by RTC alarm and press Enter. Then, select the Enable option.
    • The RTC Alarm Date option allows you to set the number of days for when your computer will be able to start on its own.
    • Specify the desired hour for startup.
    • Press the F10 key and confirm by pressing Enter when Yes is highlighted. Your pc will start automatically at the specified time and number of days that were previously specified.
결론
Als je BIOS deze optie niet heeft: Softwareoplossingen zijn beschikbaar en eenvoudig in te stellen
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Amrounassim
회원 가입일: 03/28/19
550 평판
안내서 1개를 작성함
1가이드 댓글
To automatically start up a PC at a specific time, you can set up a scheduled task in the Windows Task Scheduler. Here are the steps:
Open the Task Scheduler by searching for it in the Start menu.
Click on "Create Basic Task" in the right-hand panel.
Give the task a name and description, and click "Next".
Select "Daily" as the trigger and click "Next".
Set the date and time when you want the computer to automatically start up, and click "Next".
Select "Start a program" as the action, and click "Next".
In the "Program/script" field, type "C:\Windows\System32\cmd.exe". In the "Add arguments (optional)" field, type "/c start".
Click "Next" and then "Finish".
The PC will now automatically start up at the specified time. Note that the PC must be in sleep or hibernate mode for this to work, not powered off.
Click here more information: https://crecentech.com/
Ethan Klein - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 45
지난 30일: 258
전체 시간: 6,421
